查看: 17665|回复: 6
请教:如何建立引用集?
发表于 2005-3-4 13:49:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人在设某一零件时,想建立其引用集:“Body”,以加入装配文件时替换引用集到“Body ”,但不知如何操作?
专业人士可否帮帮忙?
谢谢!
发表于 2005-3-4 14:06:50 | 只看该作者
如图。
发表于 2005-3-4 14:20:23 | 只看该作者
sddssa:多谢啦!
多次帮了我的忙!
以后我有什么事不懂的找你好了!
发表于 2005-3-4 14:30:00 | 只看该作者
nx2 以上系统会自动建立
发表于 2005-3-4 14:58:19 | 只看该作者
我知道的有限。有问题贴帖子,大家解。
发表于 2005-3-4 16:23:26 | 只看该作者
设置UG_Metric.def后会自动过滤产生参考集
Assemblies_ModelReferenceSet: Solid(设置实体参考集
! This value can contain a set of reference set names delimited by spaces.
! These would be the names of additional reference sets that represent
! model geometry - for example if you have left and right hand parts
! represented in the same part file.  These reference sets are taken account
! of in the process of generating TeamCenter Visualization files (a TeamCenter
! Visualization file will be  generated to represent each reference set).
! It is necessary to have specified the main Model Reference Set (see above)
! in order for this option to have any effect.
Assemblies_AdditionalModelRefSets:
! This string value provide the name of a facet reference set that will be
! created whenever a part containing appropriate solid geometry is saved.
! If set any solids contained in the part (or in the model reference set
! if set - see above) will have faceted representations created for them
! (if none exist already) and added to the named reference set (which is
! created if necessary.  If this name is left blank none of this save time
! processing takes place.
Assemblies_FacetReferenceSet: Facet(小平面)
! This string value provide the name of a simplified reference set that will be
! created automatically when an assembly envelope is created
发表于 2005-3-4 19:35:00 | 只看该作者
楼上的真厉害呀
NX3可以用不?
GMT+8, 2025-9-24 20:10 , Processed in 0.048139 second(s), 11 queries , Gzip On, Redis On.
