查看: 15600|回复: 0
UG3.0安装问题
发表于 2004-11-17 14:03:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
INSTALL NOTE:
  1. Edit the included UGNX3.lic file, replace the <name> on the first line with your host name.
  2. Install Unigraphics NX FLEXlm, when asked for license file, select the modified ugnx3.lic file.
    After license server installation completed, open C:\Program Files\UGS\License Servers\UGNXFLEXlm\ugnx3.lic
    and make sure the daemon's location is correct.
    eg: the 2nd line of ugnx3.lic shoud be
        DAEMON uglmd "C:\Program Files\UGS\License Servers\UGNXFLEXlm\uglmd.exe"
    If you plan to install ugnx3 in different directory, please modify uglmd's path in ugnx3.lic
  3. Install Unigraphics NX3.
  TEAM ROR 2004
  INSTALL NOTE:
  1. Edit the included ugnx3.lic file, replace the <name> on the first line with your host name.
  TEAM ROR 2004
按以上步骤安装出现 License文件出错问题,错误代码为15
GMT+8, 2025-9-23 20:25 , Processed in 0.024168 second(s), 11 queries , Gzip On, Redis On.
